Kevinhand26@
Thread starter- Joined
- Jun 18, 2016
- 8
I got this motor not running, and now it runs but has no reverse. When I have it running on the water hose I put it in reverse and the prop spins backwards like it should the more throttle I give it the faster it turns and it seems to work fine. But when I put it in the water I have no reverse. The cable pushes the linkage as far as it will go I don't think it is an cable adjustment problem. Does anybody know where I should start looking or the possibilitys of what my problem is and I would also like to know the proper procedure for taking the lower unit off. I appreciate any help with this I'm lost
