1978 Chrysler 85hp "Charger" info
64 Sportwin
Hi All,
For $400.00 cdn We purchased a 15.5' Tri hull bowrider, trailer and this motor. All need work but the motor needs a starter which I am willing to attempt to rebuild. Does anyone have any good links or info on this motor or starter. Thx u in advance.
eurolarva
Re: 1978 Chrysler 85hp "Charger" info
Rebuild kits are really not availible for these starters. Typically take them apart and clean all the crud out of them with a can of WD 40 and Qtips. When putting it back together use some mono filliment fishing line to hold the brushes and springs in place when putting the cover back on. when the cover clears the brushes cut and remove the fishing line. If starter motor is toast you can probably get a good aftermarket one for around 120 from ebasic. Here is a breakdown of that starter
64 Sportwin
Thx eurolarva and QuadManiac. I found the same link to the exploded view. Decided to buy a new one on ebay (sstek) for $128.oo shipping inld. The manual will be a must for sure.. also found this link www.chryslercrew.com which had some neat orig docs.
Again thx for your help.
(ps I still have my 9.5 Sportwin...a true labour of love)
