Have feul, have good spark, and compression seems fine, but will not fire off.
Sparky66 Recruit Thread starter Joined Apr 18, 2020 Messages 1 Apr 18, 2020 #1 Have feul, have good spark, and compression seems fine, but will not fire off.
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 18,196 Apr 18, 2020 #2 Try starting fluid? Sometimes the needle gets stuck in the seat and won't let gas into the bowl? Loosen the bowl and squeeze the ball. You using the choke?
W wickware Lieutenant Joined Jun 20, 2009 Messages 1,286 Apr 18, 2020 #3 Share some history (such as): When did it run last? What color is your spark? Is it fresh fuel? What is the compression reading? Fire/Fuel/Compression are the needs for it to run but each has to be in a quality range. Good Luck!
