I acquired this motor basically for free. It's been sitting for I don't know how long. I did a compression check today. I had done 1 through 5 and got 105 psi across the board and as I was about to attempt to get the gauge connected to #6 when I realized I hadn't put any lube in the cylinders. All I had on hand was WD40. After giving each cylinder a good shot I started over at #1 and got 140 psi all the way down. Which reading would be more accurate and did I possibly hurt anything on the first 5 "dry runs"? I have multiple questions but will start with this. Thanks
