1978 90 mercury inline six outer prop shaft oil seal
stevehendo34
Dose the rubber part of the seal go in the housing first or metal surface?
outer seal
|~ prop shaft
~ is the rubber side of seal, dose it point to inner seal or away from it when installing?
emckelvy
There are 2 propshaft seals pressed into the bearing carrier. The first seal is installed with the rubber lips facing forward.
The 2nd seal, the one that's visible with the propeller & prop thrust hub removed, is installed with the lips facing rearwards (towards you).
HTH...........ed
stevehendo34
"lips"
That means the spring also, I think I put it in backwards :(
