I have the subject motor and am doing a little refurb and trying to remove the vertical control shaft gear and the inner control shaft gears to replace them. It appears that the vertical control shaft gear needs to come out first so the inner control shaft gear can slide out of it's housing. The exploded view shows a pin that the vertical gear sits on. Is anyone familiar with this and if so, will you tell me how to get it out?
