1978 9.9 Johnson must choke to run at WOT
tvanden
Just bought this motor. Starts, idles, trolls great. Twist the throttle to go wide open and it'll take off fine until it hits 1/2 speed and then bogs down. Pull out the choke, it runs much better and will run almost reach top end - still sounds like it could go another 1000 rpm's though. Put it back down to trolling speed and I have to push the choke back in otherwise it'll quit. What would you guys try first? Thanks!
The-Machinist
Re: 1978 9.9 Johnson must choke to run at WOT
Run down to your local OMC/BRP dealer and pick up a service manual and a carb kit. The rest should be self explanatory
Relliott
Check the Fuel Filter. It might have some trash in it keeping it from opening up. An inexpensive fix if that is the problem. If that doesn't work I would take apart the carbs.
The-Machinist
Chances are that if the filter is plugged enough to keep it from opening up the choke still wont pull enough fuel to make a difference. But, go ahead and check the screen, you may luck out:)
iwombat
"Run down to your local OMC/BRP dealer and pick up a service manual and a carb kit. The rest should be self explanatory"
Bing! bing! bing!
We have a winner!
Seriously, your high-speed jets are most likely clogged and need a good cleaning.
F_R
Honorary Supreme Mariner
High speed orfice plug (jet) is partially clogged. It must be absolutely positively clean without a trace of any deposits in the orfice. That will cause the trouble you describe--guaranteed.
