Clallamkayak
Thread starter- Joined
- May 12, 2016
- 4
I am fairly new to this whole outboard engine thing so I have been reading a lot of threads to hopefully resolve my issue but I have read so many threads that I lost and don't know the appropriate order of things to check. If someone could provide some advice and help guide my troubleshooting before I just run out and buy a whole bunch of diagnostic tools, parts, or new lower pitch prop that would be greatly appreciated.
My 1978 85hp Johnson Javelin starts fine and sounds like it runs fine. While in neutral it will rev up without hesitation and rev back down with no issues. It is currently on a 1978 19' Columbian Runabout and when put under load the RPM's stay really low and the boat never gets up on plane. So far I noticed when I was priming the motor that the fuel bulb never fully inflates but the boat never sputters when in idle or under load.
Current plan of action is to test the fuel line tonight to see if I can determine why the bulb is not fully inflating and then looking for the tach wires to install a tach. Also I can't read the pitch of the prop and will be measuring that today. Currently I can read that it is a 13 1/4 x1 but the last number is worn off.
Since the motor seems like it is running fine without out a load what would be the next diagnostic step if the fuel lines are not my issue?
