I've done a good deal of work to this motor, and finally got everything back together. It was leaking water into the bottom cylinder from multiple , so I fixed that and replaced a piston. I have great compression on all 4 cylinders now, but I can't get it to start because the spark plugs won't fire on the bottom two cylinders.
When I hook up a timing light to the #3 and #4 plug wires, I get a signal, but the plugs won't spark. I've cleaned plug wires and connections, but still can't get any plug to give me spark. I have tried plugs on the top two cylinders, and they spark just fine, so I know the plugs are all good.
I'm thinking it might be in the stator or in the trigger, but I'm not sure if I am missing anything simple. Any suggestions?
