1978/79 7.5hp outboard
Hi all,... I bought another outboard for my little tugboat, as the 1954 Johnnyrude 5.5hp set up on me, 'n I'm tired of fixin' it...
Over winter, I found a cute little Merc. 7.5hp, serial # 5146242,... I find it to be a 78/ 79 model...
I bought a carb kit for it, as it don't like idling all that much, 'n idling is what I need it to do...
I've also got a waterpump kit on the way, as even though it's movin' water, I don't know it's history, 'n would just as soon change it out, Before it's a problem...
Anyways, on to my questions,...
It's the BB carb,... Is there somewhere I can find the spec's for rebuildin' it,..??
Float level, 'n whatnots,..??
And,...
I'm assuming that to pull the lower unit, I'll need to pull the waterport screen/ cover to find another nut/ bolt holding the lower,..??
I only see 1 nut/ bolt on the forward edge of the housing...
How about the shifter,..??
Does it need to be in Forward,..??
How does it disconnect,..??
The housebarge is goin' back in, in a couple weeks, or sooner, so I gotta get the Tugbarge up, 'n running up to snuff....
Thanks fer any help ya can throw my way,.... ;)
M
Maxz695
Guest
Re: 1978/79 7.5hp outboard
if this has a zinc fin on the rear of the lower unit remove it and there may be another nut under there you have to remove onece you get the unit down in Neutral make sure you do not switch the gears when servising the water pump. then reinstal after your done and should be good to go there has to be more than 1 nut bolt holding this thing on
Laddies
Banned
Your carb is the same as this one but yours has the side fuel pump and this one has a seperate one. Make sure the idle pickup tube is clear and basic setting for idle screw is 1 1/2 out.
Ayuh,... Thank you Laddies,... That's Just the thing Im lookin' for....
Ayuh,... Day before yesterday, I pulled the carb off the motor, no problem...
Stuffed it into my coat pocket, 'n headed over to the Shop...
When I pulled the carb outa my pocket, 1 of the mounting ears was broken off, right about dead center of the stud hole...
Tore it down, 'n tanked it anyways...
Blew it out, 'n reassembled it..
I didn't really find any reasons for it to be runnin' lean, other than the ear busting off...
I "Think" I can epoxy it enough to mount it with a washer under the nut to clamp it flat, 'n tight...
But,... I figured I'd look around for a Replacement anyways...
Well,... It seems this carb is listed as NLA,...
So, Now what,..??
Is there a Known replacement available,..??
Something from a newer motor maybe,..??
I found this 1 on ebay, but it's an earlier vintage, 'n don't appear to have the fuel pump on it's side....
Can I buy this 1, 'n modify it to accept the fuel pump,..??
Any Ideas, other than my epoxy work-around are Truely appreciated....
M
Maxz695
Guest
I sent a link to you for a 1977 7.5 merc might work check your notifications
carholme,.. Yes, that's the carb.... I saved the link to the Marine power service carb...
Maxz695,.. That one appears to be the same as the 1 I linked to at ebay...
The 1 I linked to is brand new, old stock, for $83.00....
I went ahead, 'n bought 1, Hoping I can adapt the extra plate into the fuel pump, from my old carb into/ onto it...
If I fail at that, I guess I'll order the 1 posted by carholme...
Thanks guys, 'n I'm still open fer Other Ideas...
carholme
Bond-o:
http://translate.google.ca/translat...g&prev=/search?q=1364-8783A14&hl=en&prmd=ivns
I sent them an email and this is their reply:
I have 1 carburator used
price: 60$
ship:dicom collect
paid:credit card
for more question return email att:Jonathan
tel:418-337-2216
Cloutier Sports Nautiques
101 Rosaire-Robitaille
Saint-Raymond, Qc
G3L 4S7
(418) 337-2216
Maybe you should give them a call at that price.
Gerry
Wow, Way to Go,...
Thank you very Very much, it's downloaded, 'n saved to my hardrive...;)
I'll dig deeper into it abit later...
carholme,... I bought the carb I linked to, 'n an going to try to adapt it to my app...
Before I throw $60. at a Used carb, I think I'd rather double the money for a New 1 from yer 2nd link...
Thank you anyways though...
Laddies also offered me some resources from himself too...
With All the help from you guys, I see a bright future for this new tugbarge motor,...
Thanks again, to All of ya's...
windy5849
Here is the complete link to that web site.You will be amazed at all the different motor manuals for older equipment.
Thank you,for all the help you give to us!
http://search.ebscohost.com/
Log in with:
Password : public
Then select the small engine reference center icon.
Log in with:
Password : public
Ayuh,... Thanks windy, that's another Great resourse....
The Merc outboard manuals are more later models...
Well, today I went for a ride in my tugboat,..
She ran like a Dream...
To update,...
I have a rebuilt, but broken flange carb, now sittin' on a shelf in the garage,...
The 1 I found on ebay, is a carbon copy, runs like a dream replacement...
Bolted it on, hooked it up, 'n fiddled with the screw abit...
It idles smooth, 'n slow,...
At Wot, the 12' tinny is a Handfull, 'course the wind was Blowin', gale force...
The new waterpump kit went in Nicely, but the $100. for it was abit much I thought...
Expen$ive little tiny housings,...
It's pumpin' nicely though...
Another week or so, she'll be draggin' the houseboat over to it's mooring,...
Again,... Thanks for the Help, 'n advise from All of ya... ;)
I appreciate it,...
