1978 70hp Evinrude no spark
CobraFnD
I have a 1978 70hp Evinrude that is not getting spark to any of the 3 cylinders. Hot battery, spins over good. First time running it this year. Fired up on first crank, ran about 15 seconds and then died.
I am trying to figure out how to test the stator/trigger and coil pack to figure out what is the defective part.
Josephmcg
I had a mariner 200 outboard, believe it was an '89. It lost spark on 3 out of 6 cylinders, there were two black electronic boxes on the engine called 'switch boxes' one box controlled electricity to 3 cylinders, and the other box did the same for the other 3 cylinders. Not sure if you're engine is designed like that but once I got another switch box, got spark back and haven't had a problem
Joe Reeves
Remove the spark plugs when doing a spark test.
Remove the black/yellow wire from the ignition switch. If you now have spark BUT no spark with that wire attached... replace the ignition switch.
Let us know what you find.
CobraFnD
I downloaded the service manual a little bit ago and noticed one of the tests was that ignition switch. I HOPE that is the problem. Will check it when I get home. Thanks for the replies so far!
CobraFnD
That was the problem. The wire going from the ignition to the coil pack. I unhooked the wire from the coil pack, since it is a normally open connection and it fired right up. Gotta love it when it is that simple!! Thanks for the advice.
Joe Reeves
Now, ain't you the lucky one saving all those bug bucks!?.... P/Pack vs Ignition switch. :)
