barry soxman
Thread starter- Joined
- Jun 2, 2006
- 11
I am installing a used 1978 70hp motor and controls on my boat and had to change cables as the ones that came with it are too short. I found the wires cut to the chock button and a few extra wires. The switch has been changed and the wires don't match up color wise. The motor does start and run but I am not sure where the extra wires go. 1 is white coming from the engine the gives me ~8 volts when motor is running. Another white wire comes out of the controls and reads 12 volts in on position then increases as engine speed increases ti 16.5 volts. I am not sure of the other wires color coming from the controls but it shows 2-3 volts. Any help would be of great help in particular a wiring diagram. I also checked the voltage from the wire at the choke solenoid and when disconected it reads ~34 volts when engine is running?<br />Thanks,<br />Barry
