ajgraz
- Mar 1, 2010
- 1,858
Rebuilt carburetors the other night, and got to wondering...
Throttle lever on the top of the pair of carbs, part #15 in the diagram:
http://www.boats.net/parts/search/M...BURETOR LINKAGE AND CHOKE SOLENOID/parts.html
That lever is what the throttle cam engages so the butterflys will open when you accelerate. Part #16 is a "lockdown" screw that attaches the lever to the throttle shaft and allows about 45 degrees of rotational adjustability before locking the lever to the shaft.
So how do I know if the lever is adjusted properly?
I ask because the way it is currently set (and has been since I owned it) there is quite a bit of "throw" of the throttle cam before the primary pickup ever engages the lever...as in probably one third of the full throw of the handle on the control box when you go into gear. I could adjust that throttle lever so there is far less such "dead space" in the throttle handle throw. How is it supposed to be?
