1978 65hp Chrysler outboard
Status
Not open for further replies.
crappiehunter75
I'm a new boat owner and am looking for parts for my 65 HP Chrysler outboard, my question is, what is the difference in the model 659HA and 659HB? When I'm looking for parts most all refer to the model 659HB and my motor of course is the 659HA.
jerryjerry05
Re: 1978 65hp Chrysler outboard
Usually the difference is very small if any.
The points/condenser and carb parts are all the same.
What are you looking for?
Frank Acampora
HA and HB refer to year (or years) of manufacture. Depending upon engine and part there may be no difference at all or only slight differences. I would not be surprised if almost anything you needed was swappable from year to year in that particular engine line.
crappiehunter75
I was looking for water pump parts and in doing so found the question about HA vs HB. Where is a good place to find parts for this year of motor?
Thank you for you reply.
crappiehunter75
Thank you Frank, that's what I was thinking but wanted to make for certain. I'm looking for water pump impeller and gaskets. Also when the lower unit is removed is there a O ring or gasket that needs to be replaced.?
Nordin
HA or HB does not matter, everything are interchangable. This enginemodel was intruduced in 1974 as 60Hp with 2 cyl. twincarb and 818cc displacement.
In 1977 it was rated as 55Hp and in 1978 there were one 55Hp 818cc model and one 65Hp 818cc model. The 1978 65Hp had a one piece gearcase (lager then before) and the 55Hp had the older two piece case similare or same as 35-55Hp from 1966----.
The blocks are same from 1974.... for 55, 60 and 65Hp but the gearcase are different. 65Hp has the lager one piece case. The weak thing on these engines are the ign.system. Chrysler intruduced the MAGII ign.system on 60, 105 and 135Hp in 74 and this system was no good. Offen the CD module failed and in 1978 Chrysler during warrenty delivered a retrofit kit (Prestolite system similare to the Prestolite system who was fitted to the 3-4cyl. models).
The waterimpeller and house are the same as for the 3-4cyl. models, I THINK.
Looking for parts then talk to Franz at Franz Marine, he has everyting. He is not cheapest but you know you get the right parts for you engine.
BTW. I have one 1978 65Hp and one 1977 55Hp both with MAGII ign.system of my own. I collect all used parts for these engine especally ign.parts to keep these engines in running contitions.
Nordin
MitjaT I will send you a PM later.
I am busy this weekend.
Do you understand Swedish?
FT III
Nordin,
When you reference the "Prestolite system" is that a complete system or it is just the starter?
I bought a motor like this and I'm intrested in this ignition problem.
Thanks,
FT III
GA_Boater
Nordin,
Thanks,
FT III
Start your own thread. This is one is 6 years and inactive. Take a look at the Help Tip on top of the page.
Closed.
Status
