scamoot
Thread starter- Joined
- Oct 24, 2009
- 26
i've done some research on this and wondering if the readings i am getting are too high. i've only done the readings cold and i'm getting 150 on one cyl and about 145 on the other. is it true that compression goes up when the engine is warmed up? i read that it may be a sign of carbon build up on the pistons or too thin of a head gasket with this high of a reading. i am also having issues starting after it is warmed up out on the lake and it seems to be getting worse, but it may be the carbs. i rebuilt them recently, but only a cleaning was done and no new parts were put in them(next step, i know). but my main concern now is the high compression. also i would imagine that the engine would ping while running with really high compression but mine runs great with no pinging or rattling at high rpm's(after repeated hard starts of course).
thanks in advance,
ricky
thanks in advance,
ricky
