1978 35HP Johnson ignition switch color code.
Teeroy12
So I just bought this motor and The guy un wired the wires to the ignition switch and I can't find a wire diagram that matches my wire harness colors. Could someone tell me how to hook this up? The color on the wires are as follows. purple/green, red/purple, white, black, purple/white.. Here are some pictures to help with this puzzle. IMG_1947.JPG IMG_1946.JPG IMG_1950.JPG IMG_1944.JPG Thanks in advance.
SparkieBoat
the red/white should be your 12V from battery, goes to B. Black should be ground but which ever is ground should go to one M, the kill wire that goes to your power pack should go on the other M. the wire that goes to your starter solenoid should go to S. the wire going to the choke should go to C. I could not see the wires in your picture but you should be able to figure it out.
Teeroy12
Thanks, I'll try to trace these wires back to where you say they should go. Is the power pack the black modual next to the main wire harness plug?
Teeroy12
So this is what the outcome was for people with this type of wire harness. Purple and green = RASED (M), White = (S) Purple and white = (C) Black = low (M) Red and violet = (B)
