1978 25hp Johnson jumping
Ashleybsoton
Hi all just some advise, I have a 1978 25hp Johnson that I use on my 17ft starley sea nympth in salt water, and basically on idle it runs smooth but the moment you put into forward and ad revs it begins jumping and the higher you get in revs the worst it gets but only when in gear I have replaced coils, power pack, set the timing cleaned carb through, but I have noticed when I disconnect the cable and tried it on the tiller that it keeps jumping out of forward would I be right in assuming the miss is in face a worn gearbox? I'll also as a video to show you what I mean
https://youtu.be/RExQZNEFbIY
