Mr.Stuart
Thread starter- Joined
- Jul 18, 2007
- 701
I've got a 78 Evinrude 115 HP and I'm noticing that it seems to load up, or maybe run rich at lower RPM's every now and then I have to open up the throttle and blow things out before I do any extended idling, or low rpm cruising.
Is this normal? Is there some adjustment or something where I might be able to lean it out a little bit?
Just a quick description of the engine, it's a low time motor, it has 150 lbs of compression across all 4 cylinders, and otherwise runs fine, but does seem to get a little temperamental when trying to start it for the first time after a few days of sitting, it almost acts like it wants to flood out, it always starts but it can be a little temperamental at times.
