Hello,
I am a newbie to this site and I am looking for some help with my 115 Evirude (115893C). I have done a complete rebuild on the power head and lower unit. My issue is run issues and starboard bank being hotter then port bank. Bored sleeves .020 over and put new piston and rings in. Ring gap is good, piston to wall is good. New thermostats and bearings where needed. Motor start up good but doesn't like low idle and darts and pops a little. Will just stop at low idle like you turned the key off. Checked spark with 7/16 gap tester, nice blue spark. Set spark advanced to 24? with engine not running like I read on a link here. Cam mark is hitting roller in the center just as throttles start to open.
Rebuild carbs and reed blocks looked to be in good shape. Gas does run out the throat of lower carb at start but then clears up. Float levels are by the book. Set TDC by the book with stop tool.
It wants to run at 1500 but low idle is off. Starboard bank is hotter then port, (Can still touch with bare hand) but hotter. Farts and pops at low idle.
Any ideas where to start would be greatly appreciated. Hope this is the right spot for this post?
Thanks
Thanks
