The past few times on the lake my boat has been bogging down and only running on two cylinders, i would remove the cowling hit the power pack and the other two would engage and i would be home free the rest of the day, however my powepack smacking days are over now, i tried this trick again the last time out and nothing would happen. I have now replaced the power pack, the motor seems to run better using the muffs, So back to the lake, i tried again last night under pressure same problem, boat will not plane out it feels like the two cylinders get kicked on then off again over and over. . Do you guys think this could be a coil issue? I am going to get out the light gun tonight and see if i see anything irregular.
thanks for your suggestions up front
