caseycoufal
Thread starter- Joined
- Nov 3, 2020
- 4
Recently purchased a 94 cajun with a the above stated motor. Got it to crank but no water flow. Replaced impeller, cranked it with the aid of starting fluid impeller not working. Started again today, still with the aid of starting fluid, still no water. Ran water through exit valve on engine block. Water appeared to run through lower unit unobstructed. Cylinder 2 and 4 had steam coming out when spark plugs take out. Those also looked steam cleaned. Cylinder 2 has no compression, others had similar to one another but don’t remember compression. I’m not sure if it would be best to replace heads and gaskets then address cylinder 4 when heads are off. Also thinking about buying a rebuilt block that should last a while. I’m new to outboard motors so any advice on options would be appreciated.
