1977 Starcraft SuperSport 16' Engine Issue
CptnBlues63
So I recently acquired the old family boat. My dad bought it new back in 77. My brother bought the cabin/boat from dad back in 2009 and when he sold the cabin in 2014, he kept the boat. I got it from him in 2016 and did a partial conversion into a fishing boat (replaced original seats with pedestals, bow mounted trolling motor and electronics).
The Evinrude 70 hp engine still runs like a charm when she's cold but has an issue once it's warmed up that I would love to fix Once it's warm, when you try to accelerate it bogs out and will stall. I found if I hit the choke when it starts bogging, it will take right off instead of stalling out. If I feather the gas and run it for a few minutes that way eventually the rpm's do go up and the boat takes off. Once I've got it past that point, it seems to run ok thereafter.
So I'm pretty sure the issue is choke related and I'm wondering if anybody else has experience something similar with a 1977 Evinrude 70 hp engine and can tell me how to fix it?
It's not a big deal for me as I only use it for fishing and not skiiing anymore where that would be a major hassle but if I can fix it inexpensively, I would really like to.
MOD EDIT
flyingscott
Does pumping the primer ball help? When was the last time the fuel pump and carbs were serviced.
Bob_VT
Depending on how skilled you are........ I would start by a complete (tear down) card cleaning and absolutely check the fuel pump (another item easy to rebuild). If you do not have the skills find someone who does and is possibly willing to teach you.
Welcome to iboats!!
Joe Reeves
You've described the common problem that affects all outboards eventually..... Partially clogged, fouled, gummed carburetors where fuel is unable to flow properly. The choke simply allows a burst of needed fuel to get the engine past that stall point.
A sticking timer base would cause stalling BUT the use of a choke would do nothing to sure that.
BUT.... if the throttle butterflies are starting to open before the scribe mark on the metal cam is dead center with the throttle carburetor roller.... Now that would result in the same problem you describe..... check that roller (engine NOT running)
CptnBlues63
Thanks for the input one and all.
I'll have a look at the butterfly/cam first since that's an easy one to check and if that's not the issue, I'll blow some carb cleaner through it and see if that cures the problem. It wouldn't surprise me at all if it was just gummed up carbs as the boat sat in my brothers backyard without running for two years.
On a plus note, it didn't do it last night. Mind you, it was dead calm on the lake and I ran the trolling motor for approx 3 hr's without once starting the big motor between arriving at my spot and then heading back to the launch. Yes, the fish are still biting well and I had a great time last night. Fresh walleye for dinner tonight! :)
Joe Reeves
Sitting for two years...., yeah, that'd do it! Shooting carb cleaner thru the carbs is a waste of time. Tear'em down, do it right, be sure to clean the 3 high speed jets out carefully with a piece of single strand steel wire as solvent just doesn't do that job properly.
Note that even though the engine may sound proper at full throttle as it now stands, it would be running lean... and that will tear up the pistons... not worth the risk!
F_R
Honorary Supreme Mariner
Choke should be fully open when warmed up, so it has nothing to do with the stumble. You are masking the real trouble by activating the choke.
TN-25
Another thing is if one carb out of three doesn't flow fuel properly, then that cylinder will also be lean on lubrication. It is vital to have all 3 carbs pulling equally. Is there a specified carb sync procedure for these motors?
