1977 Sears Gamefisher Stalls under load
fleet captain bil
I have a mid-1970's era 7.5 hp Sears Gamefisher motor. I believe its a Tecumseh built motor. Motor starts easily, runs forever at idle, but will bog down and stall under a load. Sometimes I can alleviate the problem by pulling out the choke knob a bit, while playing with the throttle. Any ideas on how to tackle this problem would be greatly appreciated. I assume I can still get parts , if necessary. There was a time when this ran real well at WOT , like to get there again. Thanks.
MahtyMaht
Re: 1977 Sears Gamefisher Stalls under load
Your carburetor is not carbutreting. I'd check for a tear in the fuel pump element for splits, make sure all the little passages are clear of fuel gum, the needle is free, flapper valve is good, and that there are no cracks in the fuel line. You enter get your model number here;
http://www.searspartsdirect.com/partsdirect/index.action
Don't order parts from them, just collect the part numbers. Then you can go here;
Results for ESKA - Sears / Ted Wms
or call these people with motor model and part numbers in hand;
VinParts
for OEM parts.
