1977 Mercury 850 Reverse Lock
Ace1948
I have a 1977 Mercury 850 it has tilt trim. Do I need the reverse lock cam in my
lower unit or can it be remove it? I also have the old style trim pump and I have
a bad hose does any one knows who sells these hoses? Thanks for any help Ace
Re: 1977 Mercury 850 Reverse Lock
If you have power trim, you do not need the reverse tilt lock. The crowleymarine web sits stocks the hoses. About $70 each. You may need to look up the hoses on the '77 Merc 150HP motor listing. I did not see a model of the '77 850 that came with PTT.
James R
I have a 1975 850 sitting here with T/T. The pump unit is deck mounted and the cylinders are mounted on the outside of the transom mount.
Could have been an add on option but it is Mercury I think.
James, What you have is Mercury. I couldn't find a model that 850 of that year that came with PTT. So your unit could have been an option, added later or canibalized from another Merc.
