1977 mercury 1500 inline 6 cylinder
ghigh1617
Hello Folks, I am new to the forum, but not to boating. I have a 1977 mercury 1500 inline 6 cylinder that I am having trouble with at the lake. When the muffs are on the boat sitting in the yard it starts good and runs good, when I get it to the lake and under a load it will not go, it boggs down and sometimes goes dead. I have rebuilt and cleaned the carbs and changed the spark plugs. I was at the lake the other day and it came up and ran pretty good, run out around 42 mph normally tops around 50 mph, when I went back to the lake a couple of days later it would not hardly run I managed to get it on palne one time and it ran o.k. but no speed then I set it back down to idle and it would not come back up. It started bogging down again, loaded it up brought it home and here I am any help would be greatly appreciated.
thanks ghigh1617
Bt Doctur
Re: 1977 mercury 1500 inline 6 cylinder
guessing its an outboard ,so check the timing advance arm to make sure its not sticking
A 1977 1500 will have a distributor. The timing cannot not-advance. I would recommend a compression check, and then crank her up and observe and listen to the spark plug cables to see if they arc to ground. if not, check the timing. You should see 4-6* BTDC when the carbs are just about to open, and 21*BTDC at max timing advance.
if those are good, the carbs may be set too lean to accelerate. Richen them a bit and retest.
CharlieB
two stroke carbs do not have an acceleraqtor pump to provide additonal fuel for acceleration. They rely on an overly rich idle mixture. Idle mix must be set 'in-the-water' to best idle while IN Forward gear, PLUS almost another 1/8 turn richer for crisp acceleration.
ghigh1617
Thanks for your help. Should all three carbs be set the same way?
Each carb will need to be set independently. However, experience shows that the top carb runs a bit leaner than the mid carb, which runs a bit leaner than the lower carb. So the top mixture adjustment may be a bit more open than the mid carb, and the mid carb mixture ajustment may be a bit more open than the bottom carb.
