1977 Mercruiser 140 won't idle
jackball42
I have a '77 Starcraft with a Mercruiser 140 that wont idle. Rochester 2bbl. I had the boat out two weeks ago and it worked fine. Just prior to that trip I had rebuild the carb, new points/condensor, plug wires and cap. The boat had been sitting for many years before I got it and the accelerator pump was gone and there was quite a bit of varnish in the car. After rebuilding I ran some Seafoam through the tank to help clean the fuel system as a whole. I had it out today and it wont idle for nothing. The boat runs great with a little throttle and runs great at WOT. Where should I start looking? I read a post about the idle cam flipping over but havent looked at mine yet. The engine shakes a litte at low RPM's, like 900-1000.
Re: 1977 Mercruiser 140 won't idle
Ayuh,... Sounds like there's still, or more crud in the idle circuit passages,...
ya might try another rebuild....
was it soaked in solvent, 'n blown out with compressed air,..??
jackball42
I soaked it in carb cleaner and blew out the passages with air. Based on the amount of varnsih in the carb I wouldnt doubt that there is still some crud in there.
jackball42
I am going to pull the carb off, again, and get a tank of Berryman's chem dip and soak the metal parts from the carb to make sure I get all the crud out of them. I just used Gumout spray befoe.
