groovy.dude
Thread starter- Joined
- May 15, 2005
- 16
I put in a new impeller yesterday and althoug I had a few frustrating minutes I thought it went well. It all went back together and the gears worked the same as they did before. But when I started the motor up, I am not getting any water out of the pee hole. And I get lots of bubbles going out of the intake hole. When I had the lower unit off, I checked to see if the hoses were plugged using an air hose attachment, and it seemed fine. And even with it all together if I put an air hose on the pee hole, it will blow bubbles out of the intake above the prop. When the motor is running, if I put my hand by the pee hole it feels like there is air blowing out which makes me think the impeller is working. I have tried not to let it run for more than 5 - seconds like this, but I am at a loss. Does anybody have any suggestions?
