1977 Mark Twain I/O
mizdawnie
I'm looking for any help someone can provide.
We just purchased this vintage boat and the previous owners said it was in great shape and had no problems. We had it out on the lake and had been driving around at around 25-30 mph for about 20 minutes when it seemed to stall out. At that time I looked at the temperature gauge and it was running hot, so we floated about a half hour with the engine cover off to let it cool down. Oil looked fine and nothing was "overheating". When it cooled back down, I attempted to start it a couple of times and it would sound like the engine would turn over once or twice, but wouldn't start. Had to get towed in.
Any ideas of where I should start? Not sure if it is an engine problem looming or after the fact I might have run down the battery. Any help would be greatly appreciated.
Ayuh,.... Welcome Aboard,..... Is the battery fully charged,..??
Has a tune up been done, 'n new points installed,..??
Have the fuel filters been inspected, 'n cleaned,..??
Regardless what anybody Says,....
A new to you boat oughta be Serviced to be Sure everything is up to snuff,.....
alldodge
Howdy
Sorry to hear about your issues. The first time you hear from a seller that there are no issues you kind of believe it, or at least want to believe it. The second time you will know better, or at least test to verify
Which motor is in the boat?
any new to you boat, you do ALL the maintenance and replace all the parts
Impeller
points, condensor, cap, rotor
wires and plugs
belts
exhaust flappers
bellows
gear oil
engine oil and filter
and anything else pertinent to your motor/drive
