1977 JOHSON 55HP RUNNING HOT
FRANK BURFITT
HELLO I AM NEW BUT HERE GOSE I GO 55 JOHNSON WOULD LIKE SOME HELP REPLACING THE THERMOSTAT (LIKE WERE IT AT) JUST PUT IN NEW WATER PUMP AND <br />STILL MOTOR WANTS TO RUN HOT MOTOR BEEN SITTING UP SO I THINK MAYBE THE THERMOSTAT GOT A BOOK ON ORDER BUT WANT TO GO FISHING NOW THANK FOR ANY HELP :confused:
OBJ
Re: 1977 JOHSON 55HP RUNNING HOT
Welcome to the forums HD.<br /><br />The t-stat sets at the bottom of the head. To get to it, you will have to remove the head cover. This is the thin plate on the front of the head. Bout 14 bolts holding it on. There is also a pressure relief valve and seat you might want to check also while your in there. Make sure the seat is good and the plastic vlv. isn't distorted. Watch out for the spring that holds the vlv in. <br /><br />Good thinking ordering the Service Manual. :D <br /><br />Keep us posted and Good Luck!
FRANK BURFITT
Help try to put a thermostat in a 1977 55 Johnson <br />can get the motor cowl off to get to the head cover took all the bolt i saw cowl will move around but want come down ( ser man. i order not<br />here can any one help or should i wait on the UPS<br />truck) thanks hd1990
