1977 Johnson 9.9 lower unit oil leaking out prop.
bktheking
Re: 1977 Johnson 9.9 lower unit oil leaking out prop.
I wouldn't take the chance, try your old PP and fry a coil, try old coil and fry PP.
catbuster
Thanks a bunch for your help! I'll post with results.
acha8264
If I suspect that my prop seal is leaking and I submerge it in water, approx. how long would it take for the water to mix with the gear lube with the engine running.
