1977 Johnson 70hp electrical draw
Bighand2
New to the forum. Was looking online for an answer to a question and stumbled across this site. Looks to be very informative. I have a question that hopefully someone can answer. I purchased a 1977 Johnson 70 hp motor (with a pretty beat up boat) last year at the end of the season and have not had a chance to put it in the water yet. When I got it the battery cables were disconnected at the battery. I connected them and got a spark when I connected them. I left them connected and started the motor to verify that it did run. I then disconnected the cables and let it sit through the winter. Took it out from the backyard storage today and connected the cables again and the short or draw or ? is still there - not that I thought that it would go away. It appears that there is a large electrical draw in the system. When I connect the cables I hear a clicking type noise coming from under the flywheel area. I removed the flywheel and cannot see anything wrong - not that I know what I am looking for. Is this a common problem? Any help or suggestions would be greatly appreciated. Thanks in advance.
Joe Reeves
Re: 1977 Johnson 70hp electrical draw
Are you by any chance accidently hooking the battery up backwards?
Checking for a short..... disconnect the cable(s) from the positive terminal of the battery. Connect a ammeter or voltmeter between that positive battery terminal and the RED cable that leads to the engine. If a short exists, it should register on the meter. Now, it becomes a trial and error thing of disconnecting a component here and there until the meter voltage drops and registers zero. When the voltage drops to zero, you've found the offending component.
Bighand2
Joe Reeves. Thank You for the response. The battery cables are connected correctly. The draw goes away if I disconnect the stator (disconnected at the junction block). The clicking noise is also gone when one of the stator wires is disconnected. I don't think that it is possible that the ignition is keeping the stator powered up because I can start it and shut it off with the ignition. Still lost.
Joe Reeves
Assuming that the stator is faulty may be in error. It's possible that the rectifier is shorted out in such a manner that it (the rectifier) is at fault.
There are four wires leading from the stator, two (2) yellow (possibly one is yellow/gray), and a brown and a brown/yellow. Which wire did you disconnect?
Bighand2
Thanks for the advice Joe Reeves. I do believe that you are correct in saying that the rectifier is faulty. When I disconnected the stator I was also disconnecting the rectifier. I checked the rectifier with a DVOM and it seems to have a problem on the circuit that has the yellow / brown wire. Hopefully that is it. Rectifier is lots cheaper than a stator. Just ordered a rectifier and will try it to see if it corrects the problem. Thanks again for pointing me in the right direction.
