1977 johnson 70 hp, shifting rod? instalation help
wtmcihy
i am going to take off the jet drive that is on my 70 and put on a regular lower unit. my motor does not have a bellcrank rod. do i have to remove the powerhead to take the rod out of old motor and then also to replace it in mine. thanks
durban
Master Chief Petty Officer
Re: 1977 johnson 70 hp, shifting rod? instalation help
undo the shifting rod connection below the starter undo the bolts what ever contraption you, ve got on , screw the 70hp shifting rod into your gear box line the drive shaft & gear rod up in the leg & reconect the rod with the leaver under the carb
