jimwalt
- Jul 16, 2017
- 100
I am not sure if that motor has a pee hole, I know my late 60s 25 didn't and the early 70's didnt. but my point is of it doesn't all the water exits through the exhaust releifs and under water exhaust. if it's weak you won't really notice it the same as if there is a pee stream you check every time you start and put up your motor. so you will not notice a weak impellor as soon.
Yep, mine has a pee hole and it comes out nice and strong! I believe the hose for this is what I circled in red.
