1977 Johnson 55HP bogs when under load.
ragtopss
I have a 77 model 55hp engine, that starts great, and runs good at part throttle, but when you try to open it up it acts as if it is starving for fuel. The boat hasn't been in the water for about three years, but ran good prior. Before I ever started it I replaced the water pump, put new grease in lower unit. I also completely drained fuel tank and cleaned, tank looked super inside. I bought a new fuel line and cleaned the filter screen. Was wondering if a coil could cause the problem, and if so what is the best way to determine if, and which one is doing it? Engine RPM's very quick and clean when in nuetral and working throttle right at the carbs. Appriciate any help Thanks ragtopss.
JB
Re: 1977 Johnson 55HP bogs when under load.
Howdy, Ragg.<br /><br />Go to www.outboardrepairs.com and look up power loss.<br /><br />That will guide you to a sweet running engine again.<br /><br />Good luck. :)
wikelam
clean carbs work well.
ragtopss
I looked at power loss section and didn't seem to find any ref. to that problem on that engine, or how to check the coils to determine which one or if any are weak. Sorry to be a pest, but maybe I can't see the forest for the trees. Thanks again for any info.
JB
That problem shows up on any multicylinder engine, Rag.<br /><br />I have written this about 200 times and they are all on there, but one more time:<br /><br />Is it a fuel problem? Does pumping the primer get her to run? Fuel supply or fuel pump.<br /><br />Does squirting fuel mix into the carb get her to run? Dirty carb.<br /><br />Ignition problem? Does pulling any plug wire have no effect on idle speed? That cylinder is dead.<br /><br />Do all plugs make a hot, blue spark if pulled, hooked back up to the plug wire and grounded to the block? No spark? obvious conclusion.<br /><br />Hope that helps. :)
Carbs....That's what it was on my '72 Evinrude 65hp. It would run just fine under no load, but once you put it in gear and tried to throttle up it had no power. Come to find out that two of the three carbs had needles stuck closed. Cleaned them up and it runs great now.
