1977 Glasspar (Larson) TriHull w/1150 Merc
TdeAlmeida
I have what looks like an original 1977 Glasspar (Larson by the serial number and plate) Trihull runabout with a 1150 Merc Outboard. The boat and the engine are in great condition but the prop looks abused.
Does anyone know the correct OEM prop for this boat?
Also, does anyone know the original model name for these Glasspar badged boats? It looks very muck like the Barracuda 16.
Thanks in advance.
Tony D.
steelespike
Re: 1977 Glasspar (Larson) TriHull w/1150 Merc
If someone has the same boat they may be able to help.Otherwise there is no "OEM" prop size per say.If you give us the present max rpm and speed by gps we can probably make a suggestion.Also the size may be on the prop,on the barrel or perhaps under the nut.You may be able to have the prop repaired.If you look at www.fiberglassics.com you may find info on your boat.
