1977 Evinrude 70hp # 3 not firing problem
oilman850
I have a 70hp Evinrude 1977 Md#70EL77S. It has not been run in many years trying to bring her back. Compression is 140 or 143, checked coils 1 & 2 fired #3 did not fire checked coil it is new so the guy before got to this point changed coil. #3 coil is good but will not fire I am down to either power pak is bad or stator is failing. Any help to test for these two items. Thanks
flyingscott
I would bet it is your power pak 9 times out of 10 it will be the problem. That being said do the testing as recomended above.
oilman850
Thanks so much. I believe you are right but now i can verify be ordering parts. thanks soo much
Crosbyman
if I am correct CDI doc. ...
page 34 bottom left suggests to disconnect the rectifier as a quick test. If the faulty plug fires the rectifier is bad ???
but I have tasted crow .​
