This is a bizarre problem. Had the boat out on the lake for "sea trials" today. We had an issue with it staying running in reverse but it was ok in forward for a while. Once we got out past the no wake zone I was able to bring the engine speed up to 3800 RPMS and get 17 MPH out of the boat. That seemed to be pretty typical for a 24 foot pontoon boat sporting a 70. The problem came when we shut the motor down at the back of the lake for just a few minutes. It was hard to start and once started I could not give it any throttle in gear or it would die. We finally found a throttle position where it would stay running, at the "start" marking on the throttle lever, but only at 1200. Any more throttle and it would die. After heading back at 3MPH for 30 minutes we started messing around and found a very slight amount of choke (we had the cover off and applied it by hand) and the engine would pick up some and I could throttle up and run back at 3800. I experimented with it as this condition would make it very hard to recover the boat and found anytime coming off of idle when it wanted to die I tapped the choke switch (push in and release the key quickly) 3 times and the motor would pick up and run.
Another issue is when starting the engine and using the "cold idle up" lever, or what ever you call that throttle lever, it would take quite a while for the engine to build speed. My assumption was at no load the throttle response should be very quick.
This is a new to me 1977 Evinrude 70HP
New fuel pump
New fuel lines
Rebuilt carbs
new plugs
Compression 125 or better on all three
All three plugs were firing at idle but I have not checked it today.
New water pump
new Gear oil (not that that matters but....)
This is on a 24 foot pontoon boat that I've just finished rebuilding from the pontoons up. Today was the first day out on the lake.
When I first brought it home the motor ran really badly on the stand but after I replaced and rebuilt everything listed above it would start easily and seemed to free rev well. This work was done last November and the motor has been sitting on a stand in the garage until last week. I did not "winterize" it so the fuel that was in the bowls did evaporate but that happens all the time here in AZ and it's never caused me issues with four stroke motors of all kinds.
Sorry for the book but it's a crazy problem.
New fuel pump
New fuel lines
Rebuilt carbs
new plugs
New water pump
