Jasoncook48
Thread starter- Joined
- May 6, 2020
- 4
I have a 115 evinrude outboard that will not run in water. On the water it will turn over all day but never fire. When this is happening fuel starts to run out of the bottom of the carb when you stop turning the motor over. I have a pair of earmuffs if I start the motor dry and while its running turn the water on it will run smooth, however if I turn the motor off it will not start again with the water running. I have to turn off the water to the ear muffs and let it dry out for about 15 minutes for it to start again. I replaced all 4 spark plugs already to no success. Any advice is very much appreciated thanks.
