Working on reviving an old motor model 85ETLR77S,compression not great/not horrible at 112-115 each cyl.,rebuilt carbs,did the water pump and exhaust gasket in the lower unit.
After a little searching here I decided to do the vernatherm too,when I removed the housing the only things in it were the springs,don't know where the other parts went to?
Just would like to know if the attached photo shows the right assembly,with the check and spring and the vernatherm cup and spring between the tee housing and the block.The only thing in the small housing is the vernathern and the small pin.
