fire7882
- Jul 15, 2008
- 172
I have a bad head gasket and pulled the heads to do the repairs. The cylinder head with the bad gasket has corroded bolts holding the top water jacket cover on and the other one shows damage left from rings after the cylinder was rebuilt. I have access to some 1977 85hp Evinrude heads for cheap and I personally own a 1964 90hp Evinrude I could pull the Cylinder Heads from. Will either of these work with a 1988 90hp model E90TLCCA? If not, what years should I be looking for?
Damaged Head
Head with corroded bolts (2 are already broken)
1977 85hp heads
1964 90hp heads
Damaged Head
1977 85hp heads
1964 90hp heads
