fordsohc46
Thread starter- Joined
- Feb 7, 2004
- 56
my motor runs but idles rough, hard starting, smokes badly the compression is 70, 75, 75, 75. i am suspecting is needs rebuilt. the marine mechanic said it needs rings and pistons. i was wandering if i could hone the cylinders and do a ring job. i am new to outboard mechanicing and didn't know if you had to replace the pistons or if you can just put new rings. also is is possible to remove the carbs, reed valve plate, and head to replace the rings or if i have to teardown the whole engine.
