1977 85 hp johnson seahorse
ikow
Ok I started the boat on the trailer. Shift into the forward postion on the command center (was kind of stiff). Then I shift into reverse was also a little stiff, went back into neutral position and is stuck and will not go forward. I am able to pull the lever back into reverse. but will not go forward on the command center. Do I need to go into the command center to see what's going on?
boobie
Re: 1977 85 hp johnson seahorse
First disconnect the shift cable from the mtr. Then try it as it could be the mtr or the box.
