In your original post, you mentioned the kill wire. It is a real possibility that it could be causing some problems. Not just in the picture view, but anywhere along it's route to the ignition switch---or even in the switch itself. That wire can arc out through moisture, dirt, whatever. If it does arc, you will get a misfire, or possibly even quit running.
