selanative
Thread starter- Joined
- Apr 11, 2013
- 20
Right now the engine doesnt have a choke solenoid. I'm told before the solenoid went out it idled fine... Im posting this as i am confused how the choke solenoid can actually control the idle??? When i start the engine it starts with no problem but starts to idle over 1200 rpms (ear muffs only) If i control the choke linkages by hand obviously it starts to flood. The only way i can lower the rpms with out choking it is to pull back on the spark advance lever under the flywheel.
So my question is does not having anything hooked to the choke levers really causing this?
Also i have not tried messing with the idle adjustment screw yet
