krisbodean85
- Jan 17, 2012
- 6
i have a 1977 60hp mariner that it is not running here is the things that i have done to it replaced the stator with coils because i wasnt getting any sparks. now it gets sparks and i got it to crank but now it wont even try to run. still getting sparks and even if i shoot some carb cleaner in it to try to get it to crank all it does is backfires out of the exhaust. i dont know what else to do to it or what seems to be the problem. when i got it to run i hooked the muffs to it and gave it a little gas and she started acting up and then just quit i noticed my shift cable had toren out of the the wire housing and i couldnt get it to back in to neutral. but it does shift fine manualy. ordered another set of cables for it as well. but why wont it atempt to run or crank or anything like that what can it do or need to check. the spark plugs were a little wet but not much please help thanks kris
