aserioushunter
Thread starter- Joined
- Jun 1, 2017
- 2
I have about removed what hair I have left trying to restore this motor. I can't find anywhere, how to release the shift rod. I can't see a coupler at the bottom when I drop the lower unit by 1/2". Some I have seen the shift rod is released by a bolt on the right side of the motor, on top. I'm trying to replace the impeller since this motor has no water stream to tell if water pump is working. It has set for years, starts, but doesn't want to idle. I think it is an intake leak, but before I do that I want to be sure impeller is changed first. Most videos say to remove lower unit, and that is it. Any help would be appreciated.
