1977 55hp Johnson idle timing....
octofoil
Still working on my idle issues and still believe there is an issue with the carbs but wanted to go through some basic tuning. Bought a service manual to help me troubleshoot from square one. I reset all the carb linkages by the book and it certainly helped. But then I went to set the low speed timing to 3° ±1°. It was way off to start at about 12°. As I backed the idle screw off, it came off the stop and would not go any further by itself. I could push on it until the idle screw seated (I didn't force). The only way I could get the timing down to 3° was to push it down on the stop, otherwise it rest about a 1/4" off the stop at about 8°.
I didn't pull the flywheel off yet, but was wondering if there is anything else to consider. Any advice appreciated.
