unionbricky
Thread starter- Joined
- Jun 13, 2009
- 6
ok guys, got 2 problems im working on,
the first is,
got dual carbs, non adjustable jets, freshly rebuilt,
i was very thorough on setting the float hight and droop wen i was reassembling them,
but after installation at the dock, it took alot to get her started, i choked it and imediatly fuel came out, and the top carb continues to leak fuel out of the venturi at the front, its not a lot of fuel, but theres a puddle and it drips off.
at first i thought it might have been water for some reason, but after closer inspection it was fuel, the motor is hard to get restarted but
the motor will idle but erratic once restarted, the bulb stays hard as well,
before i rebuilt them it ran great at WOT but didnt dare shut it down oin the water, or it would be along time to get her going and in gear again,
now wen i opened the float bowl, the one float was way out of range, and prolly never shut the fuel off, so i know thats were the flooding came from before,
but dammit, i know the floats are right now,
now the question, do the black floats, almost like styrofoam floats get waterlogged?
they didnt seem heavy wen i tore them down, but there wasnt any fuel in the bowls as i normally run the carbs out of fuel before i leave the boat docked so they could have dried out.
second problem ill address next,
i think i got a weak shift cable, no matter how much adjustment i take out of the trunion it wont go to reverse unless i do it by hand, seems theres not enuff travel to shift it, now its just to were the dogs want to engage, and it bumbs, i have to nudge it in and she is fine to stay in gear,
theres a little slop in the plastic linkage from the were the cable connects, on the arm, below the cable to the other shift link thats on a horizontal rod that connects to the shift rod,
at the shift rod, theres not a lot of throw at the rod end, so in all the levers,
am i just loosing travel in the play, or could my cable be bad?
it doesnt seem to get a lot of travel wen shifting to reverse like there is going forward.
i took the controls apart to see how much that traveled and it doesnt seem the same as what happens at the motor.
the first is,
