1977 55hp 55773d lower end reseal
Haysc
Since the boat is winterized for the year. I want to replace all the seals in my lower unit due to water getting in. Ive never worked on an outboard but i need to learn. Im hoping the members can help me along the way. I have basic tools and im hoping i wont need any specialized tools. Here is the list of the seals i think i need am i missing anything?
O-Ring, Seal Housing qty 1 0302588
Seal, Gearcase Cover, Std qty 1 0305762
Washer, Nylon qty 2 0311598
Gasket, Cover to Gear case qty 1 0314082
Seal, Shift rod, Long qty 1 0317922
Oil Retainer, Driveshaft qty 2 0321466
Oil Retainer qty 2 0321467
Thanks!
Bosunsmate
Re: 1977 55773d lower end reseal
Ive never worked on this motor but you can normally get all seals out without specialised tools.
If using a screwdriver just be careful to not gouge the housing or especially be careful to not damage the bearings in the vicinity or drop metal parts of seal into gearcase. I put a cloth in the holes while prying/bashing out. You may need a special tool to remove the bearing carrier, depends if its a screw on or not. sometimes you just need to use bolts that screw in and push it out but be sure to only use high tension bolts-very important.
ps posting the motor hp in the title helps readers
Haysc
Re: 1977 55hp 55773d lower end reseal
Thanks for the reply! Ill keep your tips in mind! I updated the title to eliminate any confusing on HP. My bad I figured the HP /Year model in the title was sufficient. 5577
Bosunsmate
It may of being understandable for everyone else, but not for serial number illiterate me!
Catching the edge lip of the seal with a small screwdriver always works for me. Then bending it inwards and then working around the edge. Slightly knocking down on the loosened edge side normally flicks up the seized in other side.
Haysc
Thanks Bosunsmate! Oh and I'm use to not giving enough info ..I do it to the wife all the time! It sounds right in my head just not to everyone else!
Haysc
just alittle bump!:p
