1977 55 hp Evinrude choke spring?
PaulyV
I was making an adjustment on my throttle (start) tab that contacts the plastic roller and this spring came loose, then off. From reading this holds the choke open on WOT. Does anyone have a diagram of how this goes back on and where.
Motor still runs fine but I imagine once on water with a load somethings not going to be correct. Thank You.
iggyw1
Ensign
Go to a parts list (on line) and look at the carburator break down of your motor. It shows all of the parts on the sketch & will also show where the spring goes if it's a part from the carb.
